MidnightBlade
Shiftin' Smooth
I'm planning on running dual stacks made from 4x4 steel tubing. The crossover pipe will also be 4x4 tubing and 7'6" wide, it will lay on top of the frame rails and both ends will be cut at 45* angles. The stacks themselves will be 5' tall and made in a turnout fashion. The bottoms will be cut at 45* angles to match up with the crossover pipe. I am going to run a piece on 4" Conduit (Redneck at it's best) and some flex pipe to get the inlet to the crossover as close to center as possible. I know someone had some on their truck but I forget who it was.
What I really need some help with is how to brace them. Keep in mind that I'm not drilling ANY holes in my cab (rust took care of that for me) and I don't have a bed to mount them to.
Also, any thoughts for even smoke flow from both stacks?
