I was using the speed control the other day, hit the brakes turning it off, then pressed resume and nothing happened. It hasnt done anything since then. checked fuses. any ideas?
thanks
Well I fixed it. It was the clip that connects the end of the speed control cable to the actual throtle cable. it had come lose. All i had to do was clip it back in
Thanks for your effort
