david85
I ran a mix of up to 50% WMO (was actually a blend of WMO and used ATF) and the truck was a dream to drive on that stuff. Noise and smoke emissions were no different but it did have a noticeable improvement in low end torque and power that came out to play on the hills. I had to be careful to start up and shut down on straight diesel, or it would complain on coldstart. Typically the turbo would drop a good 1.5 PSI for the same amount of useable power, and im my case, exhaust smoke seemed to drop slightly.
I was only filtering through a single pass 10 micron filter though, so I didn't want to push my luck and only ran a few tanks like that. My pyro was working back then too, and I don't remember seeing any difference in EGTs, but I wasn't really pushing hard either.
When the moose pump came in and we got busy with work, I decided it wasn't worth the risk to keep running it since I just didn't have the time to make a proper processing unit, or deal with a possible injection issues so I've been running stanadyne lubircity supplement ever since instead.
Up to a 50% mix is something I would run if I had the time to make a proper filtering system - but right now, I simply don't. Thinking more about it, I may have gone as ritch as 60% but it was a while ago....
