Smoke
budget95
Mass.
My 97 F250 has been eating fuel, smoking and low on power. It's also gaining crankcase oil. Any help would be greatly appreciated.
94f450sd
somewhere,ma
Sounds like you have a cracked nozzle on an injector.if you can get it to a shop have a cylinder contribution test done on it.
94f450sd
somewhere,ma
Where in mass are you.it may be possible that I might be able to help you.
How bad is it smoking? Have a loud noticeable knock that isn't normal?
Gaining oil, that's fuel getting into the crankcase. Could it be the fuel pump, it runs off the center lobe of the cam? Sure as heck wouldn't run it like that, gonna lose the bearings if you do.
budget95
Mass.
It smokes more now than it ever did on a cold start. The oil level on the stick definatly has gone up. And yes it does have a knock.
94f450sd
somewhere,ma
Do not drive it! You have an injector dumping fuel when it shouldn't.if you drive it you will spit out a piston.you need to have a scanner put on it and run a cylinder contribution test.or replace the injectors as a set.the cct may not tell you wich one it is.
budget95
Mass.
It's a skip not a knock. I'm pretty sure it's the injector O rings. Sorry about the mix up with the knock. When I wrote that last post I had just done two 16hr. shifts in a row.
I did do a cct on it before and it checked out good. But now the comp. won't connect to the truck. Is this usually a grounding issue?
budget95
Mass.
Can someone recommend a good sorce for synthetic injector o-ring's?
sassyrel
iowa
dont know,,that they are made..the stock ones,,are just fine. they have had the material compo change twice over the period of time..make sure to lube the rings,,when you put them in...............
placidoert
