Show us your IP wrench!
Selahdoor
Index Wa
Yes, all three nuts. No problem. :D
I have "made my own" but... Prefer to use the factory wrench. I do grind it just a bit. As for the fast idle solenoid I remove it for any adjustments and... I time my engines cold if possible. To time a cold engine you remove the rear power wire on top of the injection pump and the power wire to the fast idle solenoid if your leaving that on the pump.
dgr
sac town
Wait. What? What is this voodoo? Do you just mean you prefer not burning your hands on a fully warmed up engine or are running at 2000 RPMs right after starting it and setting the timing then? Details please.
Wouldn't cold timing effect the transfer pressure in the IP? I assume it's all relative if you're setting your timing to what works best in any given truck versus a factory number that hasn't been updated since ULSD was coined.
Me. I prefer setting my timing early on a Sunday morning. Neighbors seem to prefer it too. They all come out to watch.
DaytonaBill
I'll post a photo of my IP wrench when I get home after work...
No matter how I do it, I still have to remove high idle solenoid before I can get to passenger side IP nut...
How do you guys get around that?
I hate it when I forget to do something that I said I would do, at least I finally remembered...
