JustinC00
Howdy y’all. Got a bit of an inconsistent issue. I’ve got a rough ride(yes I know these trucks ride like tanks sometimes). I posted about the issue awhile ago. It’s almost like a death wobble, for a very breif period of time (maybe 5 seconds) and then it goes away, also it goes away if I speed up a bit. My front end is all new and aligned. Tires are due to be rotated in a couple hundred miles. I’ve had all four balanced and everything is in line. I’m thinking shocks because (and I can post pics soon) the passenger side seems to have a lot more play (the piston seems like it’s longer) than the one on the drivers side. The bouncing seems to start on the passenger side (I have a Dana 50 ttb I think) and then translates to the rest of the front end. local guy said maybe the bushings in the leaf springs? Need some input. I’m using another truck for work rn, but I’d like to figure it out regardless. Thank you in advance.
