Shock Mount?
fordf350man
Rockwood MI
hey everyone. My buddy has a 2001 Ford F250 Super Duty. Rear axle is the 10.5". Both of his shock absorber mounts on his rear axle rotted away. Both of them also have a u bolt that mounts the shock mount bracket to the rear axle. We need new ones but cannot find them any where. Can anyone please let me know if they are called something else? or if it is a dealer item only? I am putting a link up on here with pictures of the axle so you can see the brackets I am talking about.
http://www.pirate4x4.com/forum/axle...ling-10-5-rear-axle-2000-ford-super-duty.html
thats the pits!
i even tried looking up sway bar mount, nada!
then i searched for sterling.
ADHD kicked in and found myself looking at uncut diamonds....cookoo
when the sun comes up, i have a SD parts truck,
ill look to see if there still on there.
fordf350man
Rockwood MI
Hey the part number helps allot. I looked on bronco graveyard and did not find anything. We are going to try the junkyard and see but now I have a part number I can take to the dealer. Thank you, I am going to keep searching now that I have a part number though and see what comes up before we go out in the cold and search the junk yard.
when you go to the junkyard, look at the F350's too.
chances are there all welded on, but would be a usefull piece of info ;Sweet
Yours is welded most likely since it has the sway bar.
Mine aren't welded at all. One was actually slightly loose.
the 01 F250 is bolted, my 02 F350 DRW is welded.
did you ever find these?
i just bought another rearend to replace my broken one, and i now have a spare set.
