Shift boot for my '93 IDI with ZF5?
DrCharles
West Plains, MO
There was a small hole in my ZF5's shift boot. Recently a rodent decided to enlarge it. Now it's about 2" across and surprisingly loud noises (gears and engine) come into the cab through that opening at highway speed.
The obvious solution is to replace it :) I thought this one would fit, but Amazon says it doesn't. Does someone have the "correct" p/n if this isn't the one? Thanks.
hacked89
Bucks County PA
This is what I used. Pretty sure it’s the same as you posted but wanted to note B vs BA. You mentioned it’s for an OBS. Also don’t think that would matter cause it mounts flush. On my one truck I took a ZF-S47 from an OBS truck and put it in a bricknose truck. Used that shift boot assembly above and no issue.
DrCharles
West Plains, MO
Thanks, found a -BA from Quirk Parts and ordered it. Cheaper than Amazon even with today's inflated shipping rates :)
m2rtin
