Set of Injection lines on EBAY maybe new
Mr_Roboto
Elyria, near Cleveland Ohio
Sounds like the seller has no knowledge of them either. 6.9 and 7.3IDI use different lines, and these DEFINITELY do not fit the PowerStroke, as listed in the ad.
Probably a good buy for someone that needs spares.
akoldnav
Anchorage, Alaska
I noticed that he used the powerstroke word also. I think most of the lines on the 6.9 and 7.3 are interchangable. The last time I ordered lines for my 88 7.3, I actually replaced the #1 line with one for the 6.9 so that I would not have that timing probe thing there. They seem to always leak and are hard to work around with the turbo hat and air filter system.
akoldnav
Mr_Roboto
The 6.9 and 7.3IDI lines ARE interchangeable, however they are not identical. (It's a trivial difference, but it's there). The 7.3IDI lines are .060" shorter.
yARIC008
Drives really slow
Orlando, FL
Must give the injectors the slight increase in pressure to pop them off sooner and or pop them off at a higher pressure seeing the injectors are different code for the 7.3's.
Mr_Roboto
You're going to love this. The 7.3IDI injector pintles are withdrawn .060" for emissions purposes. Again, a trivial difference.
