school bus engine is superduty
thedieselkid
westva
I just aquired a school bus with a 12 valve. will it fit in without spending big bucks. it also has a eaton 6 speed. i'd like to put that in also. what will i have to change to put this in a 2001 superduty??
does oil burners have a classified section??
FordGuy100
Silverton, OR
Yes it does, its towards the bottom of the main list of sub-forums.
It will take a good amount of work, but since you have motor/tranny...all you will need is wiring, peddle setup, motor mounts, and some driveshaft reworking and you should be good to go.
olsen726
