Off the top of your head do you know thick a South Bend clutch disk should be? Mine measures 1/4" and I'm thinking that might be past the wear limit.. Thanks,
Thanks that's good to know. I just removed the inspection cover then had someone push the petal while I measured the disk. Probably not the best way to get an accurate reading..
