Salvage for coil spring axle swap
kpj
Finland
Hi,
So I've been thinking back and forth about how to make ride comfort a bit more nicer. Wouldn't really matter if the roads here were good enough, but they are getting worse and worse every year. I've already swapped to d60 which was a huge improvement over d50 ttb.
So I've thought a lot about rsk super duty leaf swap, which should make the front ride better.
I've also been thinking of swapping the rear drums to discs at some point. There's a lot of reasons for that, but won't confuse this thread by listing them.
As you can read from left, I live in Finland. So basically if I need parts for especially Ford trucks, I have to import them here. So this got me thinking, if I have to import heavy parts like super duty leaf springs, rsk kit parts, some rear brake parts for the disc swap plus how to make e-brake work (caliber on kit is usually some :puke: GM stuff), which is mandatory in every year inspection. Those would add about so much that I'm starting to lean on '05+ coil spring swap and importing a salvage donor truck for it. Bonus also would be to have a bigger brakes all around and available 4-link kits to front. I've been looking around and seems that the easiest donor would be F250 or F350 from 2005 to around 2010, since they all should have the same d60 front and same rear axle also. Diesel models probably have better suited spring rate for these heavy engines.
So my question is that, where do you guys buy your parts trucks? Do you usually buy them from copart or something like that. I've searched the net and most of the salvage yards doesn't have very good webpages or doesn't advertise much. Can you recommend a place where i could find one. There must be thousands of salvage f350 diesels over there to choose from. Wouldn't mind if the donor wouldn't cost an arm and a leg. Cheapest to ship here is also South, South-East or South-West of USA and South-East the cheapest of them.
If i could choose some options, obviously 4x4, cab doesn't matter, axle ratios 4.1 or 4.3. If it's been crashed, the chassis should be ok with all the parts in it and wheels/tires too, since newer truck has different lug pattern.
What do you think is the realistic cost for the donor truck?
Hope that someone had time to read that, it came out a bit long, Thanks!
aggiediesel01
Houston, TX
I read recently that there was another break in axle design after '07. The info I read stated that in '08 the unitized hubs in the front became larger/more reliable and the brakes are even larger (I believe you have to run 18" rims). Also Ford brought back the 3.55 ratio in '08 for better economy.
http://www.car-part.com/
is the place to go for wrecking yard parts not sure of any better for whole vehicles than copart. You can try one of the Craigslist aggregator sites, facebook marketplace, or Ebay.
nj_m715
government's finest
NE of Atlanta
car part is nice
in my day searching for junk yard parts meant getting muddy and getting stung by hornets
kpj
Finland
How could i forgot the car-parts, been there many times. But seems like they're more like parts search, couldn't find a whole vehicles.
Did some research and looks like i just have to find a deal from copart or their broker pages like https://www.autoauctionmall.com, https://abetter.bid or https://www.autobidmaster.com. Some of those even offer international shipping. Craigslist has plenty of stuff for sale also. Facebook is something that i can't do, don't have an account :eek: ...
About brakes and hubs, didn't know they changed. Just checked Rockauto.com and it lists most of their hubs between 2005-2010, but there are some hubs also to 2008-2010, so something probably have changed, but can't figure out from the pictures what...
Cv axle
