?'s on duals
u2slow
bilge rat
PNW
19.5" wheels and tires can support up to 5000# each. On my E350, it was easier and cheaper than going DRW.
charliee22
Bartlesville Ok
the studs on my f350 single tire are the same length as my buddies f350 dually but i dont know about the frames on the older trucks.
stonecrusher
ohio
Honestly I couldn't see ford going to the trouble of making 2 different frames. The dually rear ends in most applications just have longer studs and/or the axle tubes are a little bit longer. The frames are the same I measured them today just to back up what I am saying.
smokin_stroker00
dover ohio
They do make more than one frame my 2000 f250 is 37" wide and curved
my 2000 F350 cab and chassis is flat framed and is only 34" wide
Diesel_brad
Dunce
gilbert pa
But that is what I have is a single wheel cab and chassis
NO SRW trucks left the factory without a bed. They were built as a pickup, delivered, bed removed then a utility, flat, or some other custom bed was installed. A true cab-n-chassis has a flat frame and is 34" wide. AN industry standard
Diesel_brad
Dunce
gilbert pa
Yes. Ford made differnt frames for cab-n-chassis and regular dually pick ups
Tyler9828
