Rustproofing opinions? Converter vs wire wheel
should I:
  • strip it
    Votes: 3 100.0%
  • convert it
    Votes: 0 0.0%
  • Total voters
Selahdoor
Index Wa
Its encased in an epoxy like substance, I’m under the impression the aluminum forms a matrix that just strengthens the whole thing. The epoxy/bonder would block any electrolyte and galvanic corrosion can’t happen. We actually use a similar Wilco product on the pipeline for above ground piping which is obviously carbon steel. They’ve been using that for about 30 years.
I’ve used chassis saver on several projects over the past two years and so far seems to be working perfect.
Thank you. :D
saburai
I see you're in Florida, are you near the coast where everything is salty?
Diego is from central Florida, as you can see, frame corrosion is much less of an issue than top side rust. NY = bottom up, FL = top down. As you know, we're on a west coast island, if you're parked right at the water like you work at a marina, yeah, stuff rusts up. Just a mile inland and it's not so bad.
Alleycat
