zacky6661
hey OB, been a while since ive been on but ive been busy moving. anyways a couple of new quirks have surfaced on my 84, first off the temp guage is reading WAY hotter than normal, not to the point of overheating but very high. i know factory ford guages are just idiot sticks in these but its never done this before. the part that puzzles me is that the heater doesnt blow any hotter, and if i pull over and pop the hood the upper rad hose isnt any hotter than normal temp turn the motor off and you can touch almost any part of the engine bay without getting burned. could this be a temp sender malfunction? or a thermostat?
another thing that came up, not on the same issue but when i come to an idle theres a tap that comes from the front end of my motor, at first i was wondering if it was a valve tick so i wasnt too worried since i plan on rebuilding the top end with this years tax returns. but my friend says it sounds like a timing chain with slack in it since after i give it some go-juice the tap goes away, is this something to be concerned about?
