burtcheca
farmer/cabinetmaker
I would like to add a RPM gauge to have an idea how fast the engine is revving. Has anybody done it? Where do I get the gauge and accessories? Where do I need to install it?
Thanks,
Burt.
Thanks,
Burt.
Yes, there is a big plug just a couple of inches to the right of the oil filler. Is it there where I need to install the sensor, or sender?Just look to the right of the oil filler and if there's a big plug then you're OK. If it's smooth then you'll need a later style IP housing.
That's it. Does the van harness resemble the truck harness? Look to the passenger side of the IP housing and see if you have a two-wire connector not being used. The wire colors should be Black/Lt. Green and Dk. Green/Yellow if it does.
