Replacing Power Steering gear
adill
Utah
Hey guys, I have looked for a while to find a post about removing the power steering gear, but can't find one. I am trying to remove mine cause it has a bad leak. I have the lines disconnected from it, but the pitman arm pullers i've been renting from autozone won't work because of the angle. It won't go on cause it hits the front differential.
Does anyone have any suggestions or pictures to help me out? Thanks in advance!
Two hammers remove ball joint from pitman arm...remove gearbox and then remove the pitman arm...
GaryB
