Replacement coil springs
SLittle
Iowa
I have a '91 F350 Dually, crew cab, 2wd thats all stock. I have the front suspension out replacing pivot and radius arm bushings. I've already replaced tie rods, ball joints, etc.
Looks like the only thing left is the coil springs. They aren't broke, but its disassembled and they aren't usually expensive, however...
I can't seem to find the proper OEM replacement spring listed for my application.
I can find single cabs and cab & chassis listings. Not seeing crew dually.
Anyone have any advice?
u2slow
bilge rat
Coastal BC
Let your alignment decide, as with TiB its about finding the height sweet-spot.
Engine weight likely matters more than dually or cab size.
