reklund
Hey guys-
I've had repeated return line O-ring failure on the same cylinder. About 6 weeks ago, I began smelling Diesel when I approached my truck after it'd been parked. As the smell persisted, I traced it to leaking return line O-rings on the #5 cylinder.
I replaced only the O-rings (while I awaited an entire return line/cap kit to arrive) and the problem was solved. There was no obvious signs of a failed cap, and the old O-ring did show signs of being pinched (which is weird- it was on there for over 2 years with NO issues). Today, same leak, same cylinder. I haven't pulled it apart yet, but am curious what may be causing it. The truck runs/starts/drives normally, but leaks diesel.
Possible bad injector sticking open causing combustion pressure to be forced into the return cap? Can that even happen? Is my truck telling me it needs a Moose Pump and Moose Misters?
Ryan
Ryan
