Ataylor
I have a 1987 F350 4x4 with a C6 that I would like to pull the engine and transmission without separating. I have removed the transfer case. I have the front clip and radiator support removed. Is it possible to pull the engine and trans together, or should I drop the transmission from the bottom and pull the engine. I have a cherry picker at the house, but have access to a gantry crane if needed. Thanks for any advice.
Archie
Archie
