I just overhauled my C6 and I can manually shift it to first but when coming to a stop it doesn't shift its self to first, it seems to down shift to second, anything come to mind? I hope it is simple!
It may not be the governer I have rebuilt so many at least over 400+ C-6 units in the last 20 years it. Was the valve body cleaned and torqued? Boost valve replaced? Low reverse seal installed correctly? Also need to check the blue spring and cut back spring in the valve body!
Thanks guys, runing around in the yard it seems to be better after reverse trick, I tried this with a chebbie ban at work, seems to help it too, boss is happy,
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
