rebuilt C6 won't downshift at a stop
NapaBavarian
Dually driver 6.9
Napa CA
I just overhauled my C6 and I can manually shift it to first but when coming to a stop it doesn't shift its self to first, it seems to down shift to second, anything come to mind? I hope it is simple!
tenlug
Try a pint of Chemtool and "rattle the govenor".
IDIDieselJohn
0-60....eventually
Ottawa Ontario
Go in a appropriate area, and give it a good long hard quick run in REVERSE.
Do it a couple times if necessary. This flushes out the governor and other parts inside the tranny.
Usually this trick works for a sticky governor.
ford390gashog
brentwood
It may not be the governer I have rebuilt so many at least over 400+ C-6 units in the last 20 years it. Was the valve body cleaned and torqued? Boost valve replaced? Low reverse seal installed correctly? Also need to check the blue spring and cut back spring in the valve body!
NapaBavarian
Dually driver 6.9
Napa CA
Thanks guys, runing around in the yard it seems to be better after reverse trick, I tried this with a chebbie ban at work, seems to help it too, boss is happy,
JU57US
