sle2115
NRA LIFE MEMBER
Purchased a used oil cooler from a member here (thanks greg ) and wanted to go through it and have it ready to install. I am getting a ton of oil down the d-side of the motor, valve cover is leaking and I'm going to start there. Anyway, after seeing the picture that Calvin posted, I'm gunshy of breaking this thing down. What method have you all used in the past? I'm going to have it cleaned at the machine shop in the hot tank and wanted to take it apart before doing so. I'm going to put it together and my old boss said I was welcome to use the pressure test bench to verify no leaky. Just wanted to know how you guys are popping them apart.
