Rear suspension sag
ropen699
San Luis Obispo, CA
I have a 92 ford 250 and the rear is sagging out from all of the weight of my tools. I was thinking I could go to the junk yard and get one ton leave springs and shocks and just bolt them in to the existing mounts. Will this work? Do you guys know if the parts are interchangeable. Or does anyone have a better idea. Thanks
93f250idi
strokin
cadiz ky
im 99% sure it will work as long as its not a cab an chassis truck that you get them from.
Diesel_brad
Dunce
gilbert pa
F350s use the SAME rear spring as the F250s. The ONLY difference is the F250 uses a 2.5" block and a F250 uses a 4" block.
I would either get an add-a-leaf if you are always loaded or a set of air springs of only loaded some of the time
