davlun
Hello,
Getting ready to attempt an axle seal for the first time and had a few questions after research online:
1) After removing the bolts at the end of the axle, it says to remove the hub, will i need a puller always, or just sometimes
2) when replacing the axle seal, is it readily apparent where the seal is supposed to line up, or is there a measurement
3) when reinstalling the bolts at the end of the axle, it says to use a water sealer, i assume to keep water from getting in. great idea, but what product is that?
Thanks,
David
Thanks,
David
