spencergt66
Ok so i got some work done on the truck today, made a new air intake and replace the front brake pads. But still had a week pedal ie low pedal so obviously i needed to adjust the rear brakes but i cant get the spacer off the dam hub i dont seam to have a socket thin enough is there a special tool? also it seams that the top pin is missing where the brake shoes pivot right above the the wheel cyl on the right wheel im sure this is where myproblem is but cant seam to locate a new one any sugestions
