the only thing i noticed is at an idle there seems to be a hair more blowby, but still next to none, im wondering if it was just cause its a little chilly today, but when i rev the engine via fuel pump it goes away instantly like it always did, and i looked under the truck and i cant tell if theres a small knock or if its just the rattling from the injectors, i have my exhaust hacked off at the back of the cab so its a little hard to hear over but other than that its still chuggin just like it did when i got it, im really thankful nothing bad happened....
for my 97 psd, i hydrolock my #7 cyl and it split the whole way down the sleeve. a resleeve fixed it. but i didnt see any performance issues or noises. and didnt know it was cracked till it was torn apart for a different issue.
would i have been able to tell if i hydrolocked the motor? i went out yesterday, and it was a bit of a pain to get it started, then again my starters goin out, but the motor was just turning over a bunch but not firing, actually had to give it two 5 second glows from the plugs instead of one before it finally roared to life
if the starter is weak, it may be hard to start. IDI's need to spin fast to fire.
You should be ok. You would have known if you hyrdro locked it...aka either the motor wouldnt turn over at all and or internal stuff bends and breaks. If it is running the way it was before you are ok. It could have also ran away from you using the chemical as a fuel.. that would have also been obvious as the motor would have accelerated up uncontrolably and also breaking internal stuff because of excessive RPM. Yours did niether. Just dont do it again and you should be ok.
NEVER use ether to start a IDI!!! The precup and glow plug location will work together and tend to blow-up/explode/do expensive damage to your engine!! With this said, I know some people do this, usually in a survival mode, but do you really need or want to take that chance? Fix the glowplug /block heater system instead.
Don't freak out if you pump gasoline into the diesel tank. Most of us have done it at one time or another. Just so it is not a lot, just dilute it with diesel and keep on going. Should it be a lot, the engine will be low on power and, as I understand it, hard to start. Then it is up to you to drain it and either use it elsewhere, or return it back in the tank a little at a time. Not good on the lubrication of the injection pump, but in moderation I doubt the lifespan [or mean time between failure] can be measured outside of a lab situation. But as the owner, it is your call.
