Good evening all, didnt check the hpop oil level, not sure where to find the resevoir. brought home a gensis scan tool, hooked up and checked current codes.....p1280 icp circ out of range...p0113 iat high,,,, caused that one by removing the air box...p0344 cam pos sens circ int...p0340 cam pos circ malf.......went through all the koeo and koer tests and came up with enough codes to drive a sane person crazy,,not to far from there myself. any way the next bunch were p0196 eng oil temp sens circ...p0475 exh press ctl valve...p1294 high side open bank 2
...p1298 idm failure... koer..p0476 exh press ctrl valve perf.... now the question is at which end of this animal do you start... i am thinking the cam sensor may be the root of most of these problems some of the faults could have been caused by my own errors in disconecting sensors and injector harnesses with the engine running... any thoughts. R Greene
