ran like crap on 1/3 Diesel, 1/3 ATF, 1/3 WMO
broncobilly_69
Lebanon, OR
Anything you guys running the higher concentrations are doing to make it run right? It would often die when it was idling at stop lights and such. Other times it would idle fine. Topped off the tank with #2 and it smoothed right out.
Any suggestions would be greatly appreciated
broncobilly_69
Lebanon, OR
must be the lift pump. I tried changing the fuel filter and that didn't solve te problem. Is there a way to test the lift pump?
