Question about User Status
Wideopen
It's all about me.
TS Perfomance Baby!!
When will mine change from Member to something Else??? Do you have it set up on Post counts or what..or is Member as high as a use can go with out you or the Administrator changing it?? Just checking?? I also see that SMD is labeled as a Dunce...thats Funny..
Max Power
Member is as high as you can go. I can change the status to any custom settings i want and also any posts counts i want. I will gladly take suggestions.
In the control panel you can chage it to say whatever you want. (within reason)
Max Power
Since your avatar is of Pauli, I changed you to a 'Capo' You can change it if you wish :D
Wideopen
It's all about me.
I like it....I guess I'll run Paulie for a while.."Capo" Sweet
