dyoung14
Is getting worn out
Di heads wont fit on an idi block because the cylinder spacing is differant... I did look into this years ago... even bought adi exhaust manifold trying to fab up a differant trubo up pipe set.... Spacing wrong... The di is a 7.3... The pistons are the same size as our turbo pistons are but the tops are way differant... Wont work... The di rods are the same length and the pin and bearing is the same diameter but... The bottom end is 130 thous wider so it wont fit without lots of machining... Then it will be too thin for a secure hold to the crank...
could we use PSD pistons in a 7.3 IDI
