ps
94f450sd
somewhere,ma
:confused::confused::confused::dunno
ok ill bite.im guessin you stuffed a 60 series into a pickup?or u messin wit us cuz the 60 series is heui engine?
LUCKYFORD
mtn view oklahoma
sorry whole post did'nt make it. smokes when in P revved up about2400 gets rough and smokes oil then clears at 2600 runs great and does not do this on the highway?
LUCKYFORD
mtn view oklahoma
russ thats kinda what i thought found some new injectors for 275. the ruck is an obs 95 all stock except straight exhaust
I assume P is Park, and just starting engine. At 2600 RPM with a load on the engine re; driving down the Hiway and no Smoke, 1st thing I would do is check your UVCH (Under Valve Cover Harness) on both heads to see if either is connected solid. Not knowing what year you have it can be one or two connections on each head, the earlier models 2000 and down have a tendency to slip out, the latch inside the cover didn't hold.
GO HERE FOR INFO ON THEM.
mitsu tractor
