Promise... the build
Selahdoor
Index Wa
Is the blowby, excessive?
Selahdoor
Index Wa
IMHO.. no.. that's not even a quarter of what mine looks like. Mine looks like a freight train pulling a hill, still runs good and doesn't use much oil. And passes emissions with 4-5% opacity...
Thank you.
It should be on my page here unde the fuel system parts, and in a recent post on the Facebook page with some injectors in the picture. $10 shipped for a set of 16
Selahdoor
Index Wa
Well, I don't normally move along very quickly with these things, and this one is no exception.
Today, I did whatever I could get done. Mostly I am waiting on parts.
What I know at the end of the day...
The check valve on the top of the IP that goes to the return lines... Is fine. I took it out and checked it out. It was difficult to blow through. But then I got out a bright light, and put on a good pair of "inspection glasses". LOL Looked clean, through and through. Then used a pick to very gently poke at the glass ball... It moves freely. No blockage. No grit. Nuttin!
Got all that back together. Checked out the incoming and return lines. Everything is good.
Then I blew through the return line, back to the tank. There was a tiny bit of hesitation, then it popped, and suddenly it was easy to hear burbling in the tank every time I blew on the hose. So... Maybe there was a bit of obstruction in there? Possibility. But I don't think that was the problem. (Cause of the loping idle, and the smoke.)
(Side note: Diesel doesn't taste quite as bad as gasoline. But has a greasy aftertaste. ;))
I have a question...
The return line that goes back up to the fuel filter.
That fitting in the fuel filter housing...
Is there supposed to be a check valve in there, as well? And if so, which direction is it supposed to flow?
Cause when I pulled the line off of it, there was a very steady stream coming out of the filter. It was strong enough to reach and drench the IP. And the stream stayed that way.
This was with the engine off and cold.
The gauge and other parts can't get here soon enough. I want to check the compression correctly. And I want to test injectors so I can put a balanced set in there. Then... I will try changing the pump timing.
The_Josh_Bear
Western WA
That check ball in the filter housing is supposed to let that tiny stream of fuel/air out and into the return line(but then keep air or fuel from pushing back into the filter housing when turned off)
This is strictly for air removal, and is a great passive system. However if you pulled the line off and it shot onto the IP you have a clog in the return system(or DID, you said you blew through it). That is unless you had an epump running and didnt mention it.
Oh and that little ball takes about 0 psi to open, the spring is really really light. There was a TSB about eliminating that line altogether due to air intrusion. But its terribly convenient for running out of fuel or priming the system/bleeding injectors.
Selahdoor
Index Wa
Ordered a new gauge to put into my compression tester, so that I could get a more accurate reading.
What showed up was a tiny little gauge. Moral of the story, pay closer attention to the details when you order stuff from amazon. LOL
I immediately ordered another gauge. It should be here next monday or tuesday.
BUT.... I have waited long enough. I was anxious to see what the compression is really like. So I put the tiny gauge on it, and did the readings.
Small as it is, it did give me readings down to 10 pounds.
So, here are the compression readings:
Firewall
420 ... 390
390 ... 400
360 ... 420
380 ... 360
Radiator
Not the best, but not the worst either.
What do yall think?
YJMike92
NW Arkansas
Firewall
420 ... 390
390 ... 400
360 ... 420
380 ... 360
Radiator
What do yall think?
I'm not sure what the specification is but that's not bad. It would be nicer if there was not as wide a gap between the lowest and the highest readings. I will try and find an official spec tomorrow.
bbjordan
Snow Monkey
Ashern Manitoba
Those readings look ok. If it were mine I'd throw a can of SeaFoam in the crankcase and leave it in until the next oil change. It's good for unsticking rings, and it shouldn't hurt your engine.
I'm really interested to see what the injectors test at. There is really no point in setting the timing until the injectors all pop at about the same pressure.
It must have been a great feeling when the engine came to life. :)
Vincent
