Project: The New CDD Shop Truck
Thewespaul
Bulverde, Texas
Alrighty folks well about time I make a thread for my 93, I bought this truck for $3500 from the original owner with 130k miles, it now has over 260k and is ready for a new engine after the beatings it’s taken over the years, this truck has been a test mule for myself and has been fed nitrous, water ****, propane, and wmo. Engine is chuffing out the exhaust and burning a grotesque amount of oil. So that brings you up to date on that engine.
Last weekend I picked up a parts truck for $1100 delivered, it’s an idi turbo engine and a 94 with the better serpentine setup which was a must for me after dealing with so many accessory issues with the open style tensioner. I got the engine started after the truck had been sitting for over a year in a yard and drove it up onto the flatbed.
After finishing up as much as I could on Project Jerry with the parts I have here, I pulled the engine out of the crew cab yesterday. Did it the right way by pulling the front clip since a member on here is taking the rest of the truck, and set a new personal record. 2 hrs and 7 minutes to pull it solo mente, pretty happy with that.
Pulled the pump off my 93 since the baby moose has been sold and is shipping out tomorrow, so I pulled the pump off the turbo engine and swapped my fittings into it to run it in the 93 in the meantime.
Currently pulling the turbo engine apart, got the accessories and valve covers off. So far it’s looking great inside.
Very little pitting on the timing cover
Thewespaul
Bulverde, Texas
Engine torn down to a short block, everything still looking great so far, just a burnt exhaust manifold gasket
Thewespaul
Bulverde, Texas
Now starts the fun stuff, reassembly. Knocked out all the coolant plugs and pulled them out off the head and block
Cleaned up the mating surfaces and the ring ridge, all the pistons look great and the cylinder walls look pretty good for the 200k that’s already on the engine.
I’m using 6.9 felpro headgaskets so none of the coolant passages are blocked off and they come with these mls/rubber inserts with tiny pinholes for the coolant passages at the lower corners, something I’ve started doing is widening that passage with a cutoff wheel, I like to have good coolant flow.
Used set of headstuds I had go in after a thorough cleaning of the threads, I don’t use a tap but modify a headbolt to chase the threads. Takes times but you want each stud to go in by hand and you should be able to take a straight edge across the tops of the studs and touch each one.
Went to start on the passenger side and went to grab the headgasket out of the box and what do ya know... my “set” came with only one gasket... thanks @RockAuto. Going to work on other things in the meantime but this engine probably won’t be running tomorrow like I was planning.
no mufflers
rhode island
when i did my head studs i just drilled the same size hole in the freeze plug. not sure how much flow that area sees but it doesn't over heat any more.
Thewespaul
Bulverde, Texas
Yep that’s another way, I prefer to knock them out. Both ways are better than plugged.
Anyone spot what’s out of place about this oil cooler?
Painted up the main oil cooler cylinder after stripping it and cleaning out each coolant tube
Exhaust manifold stripped and coated
Thewespaul
Bulverde, Texas
Knocking out more prepping and painting. Got my single head gasket ordered should be here Monday.
HEY! Your silver color is shinier than mine. NO FAIR! I guess you're using an aluminum color while I used a cast iron color. I wish I would have thought about enlarging that hole in the insert. Oh well. Even the little, stock hole will let more coolant through than a plug will.
Thewespaul
Bulverde, Texas
:p:p:p
I’m gonna use the dark ford blue for the block just to be different from yours, I think the brighter silver will offset it nicely.
Shiney...
Thewespaul
Bulverde, Texas
Here’s the two colors next to each other and their paint codes
They do look good together. Personally, I'm not sure about painting the filter housing blue, but it still looks good.
Thewespaul
Bulverde, Texas
I have no use for those stock parts! I do so many of my intake kits that I have those stock filter housings just laying around
Thatoneguy
Boerne, Texas
May be a dumb question... But whats your intake kit?
Sent from my Moto Z (2) using Tapatalk
DougsOBS
So you pulled all coolant plugs from the heads and block? Debating on doing that to mine
