Update time. Picked up an intake hat.
After 2 failed attempts to get the correct spring pad spacers from 4wheel parts, I finally gave up and bought a sheet of 0.625" nylon impregnated with moly sulfide and made my own.
I put my front springs together complete with new wear pads and urethane bushings.
The rest of the front axle parts.
I bought the tough country UBolts for the front and they didn't fit very well so I had to make some relief cuts in the top plates to accommodate the radius of the bolts.
Set the axle under the truck with the motorcycle jack.
I bolted the axle up to the springs and then torqued the king pins. Unfortunately, I didn't take pics of that. Built torque multiplier 6 ft long and set the torque wrench to 125 making it 625 ft lbs.
I put the axles together with new ujoints. All was great until I broke one of the caps on my spicer joints.
Ended up getting a Moog joint to finish up. Put the spindles with dust covers and caliper brackets.
More in a minute.
