Project: asmith
Clb
Another old truck
nannyfornia
Vato zone... I have taken to making them test the brand new product before I pay...
3 alt' s on the yota in 1 year, 2 vato zone and 1 factory(its now 5 yrs old).
Wanna talk airtex pumps?
Exciter curcuit next???
Effin nice work truck right there asmith.
@asmith
theres your first 3rd party opinion!
I took CLB for a ride in it yesterday, bets he's gonna do a cam swap soon :)
issue is with the stock wiring harness.
just slapped another one in and its still not working.
on my powermaster, It don't use a green wire, whats this wire for?
asmith
Atascadero, Ca
Glad CLB likes it! I can't wait to see how she goes. Bummer your still having issues with charging. Hope you find it quick.
so, i just returned the last alternator from vatozone.
they had to test it, and it indeed failed.
what are the chances of me getting 3 dead alternators in a row from 2 different stores???
going to check if i have an extra alt pig tail, lets hotwire this batch
Hydro-idi
Lodi, California
Yeah it's common. That was me with Azone starters about a year ago. It might take 10 or so, but you'll eventually get a good one!
aaaaaaaand im done IDIn for today.
decided to make a hotwired pig tail(without the greenwire) from the other harness,
went to go put it on,
whos got two fingers up, and drops the charging stud nut behind the alternator bracket??
:Thumbs Up
oops wrong fingers.
:flipa
ok, i pull the belt off, loosen the bolts, retrieve the nut, put the nut back on, tighten alternator charging nut,
went to put the belt back on,
guess what strips?
the damn idler bolt threads.
i give up for today.
time for rum.
grabbed another tensioner,
got it fixed and put back together,
no charge...
gotta be the f'n alternator.
I have shopkey and can give you a nice diagram if the ground doesn't work. it sounds like that could be your problem.
mind if i take you up on that diagram?
im loosing my mind over here over a damn alternator that should be simple.
It’s not one of the goofy ones where if the bulb goes out the alt doesn’t work is it?
Can you pull a known good alt off another truck to test the system?
ive ***** my complete alternator stash.
the only one i know that works that i have is a mini 200A GM 1 wire(cost 450$)
and the powermaster on my truck.
i do not rob parts off my truck for testing reasons.
you've gotta be ******** me, they have those?
even tho i know its not charging, there has never been a battery light
Vinceslamer
