Pre fall get together repairs.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
A couple weeks ago I lost a freeze plug behind the clutch. Needless to say, this prompted a bunch of repairs including:
-ceramic clutch from Pheonix Friction.
-replacement 093 up pipes from Russ.
-new o rings and grommets for the turbo pedestal thanks again to Russ
-ZF shift boot from Ford
-transfer case shift linkage bushings
-RDT to further eliminate the oily mess on top of my engine.
Pic 1- No, it's not a fancy water cooled clutch!
Pic 2- getting to old to struggle, hence new trans jack.
Pic 3,4,5- the tight squeeze fitting a lifted cclb into my shop
Pic 6,7-new 093 cast up pipes and install kit
Pic 8-almost shot old clutch
Pic 9,11- new ceramic clutch kit
Pic 10- pin holes on my old cross over pipe
Pic 12,13,14- some redneck rigging to pick up the ZF5speed and get it on the jack for the install.
Pic 15-18- pulled turbo, install kit even came with the pedestal grommet, winning!
Pic 19- picked up some 16x10 Weld rims to upgrade from the current 16x8's.
Sent from my SM-G960U using Tapatalk
subway
be nice to the admin :D
York PA
do you think the freeze plug rotted out or was it a bad install?
anyway, nice work, i know what you mean with taking it a little easier on the body. one of the reasons i am adding a winch on the front of my truck for firewood. let the machine take the abuse!
Danielle
No, it's not finished
Dirty Jersey
Holy cow! What an undertaking [emoji43] but it feels good to get it all done and know it is done right and with the parts you pick
Sent from my VS501 using Tapatalk
GOOSE
Happy IDI'er
They are stainless freeze plugs, every other one appears to be perfect. I'm not really sure why it went. This is the second one though so the curiosity has me as well. Engine comes out next time.
GOOSE
Happy IDI'er
Put a 1/4" rigid coupling in for my EGT probe. Fitted Russ's two piece cross over pipe, tacked it and pulled it back out for a bench weld.
GOOSE
Happy IDI'er
Some fresh fluids for the transfer case.
GOOSE
Happy IDI'er
Gave up on the CDR and ran a piece of 1" for a RDT.
GOOSE
Happy IDI'er
Gave her a good hard run. Will check fluids tomorrow to make sure nothing mixed, top off coolant, pick up new transmission and floor board shift boots from Ford and tend to a couple of other small things before the trip to Michigan. Oh yeah, boost went from a laggy 8psi to a quick spooling 13psi with a waste gate adjustment while the turbo was on the bench.
subway
York PA
i am almost surprised it did not hit higher! those were some serious exhaust leaks. i would try to clean off as much of that old carbon as you could, you don't want that stuff promoting rust.
GOOSE
Happy IDI'er
I've burned through 6 cans of Brakleen washing down the oily soot residue.
GOOSE
Happy IDI'er
Ford is mighty proud of these things @ $93 a pop. The difference is night and day as far as noise suppression.
GOOSE
Happy IDI'er
All the oil leaks had me weary. Got rid of the mechanical oil pressure gauge in favor of one with an electrical sending unit. One less leak to worry about. My OCD is happy as the sweeps on the gauges now match.
