Power steering
94johnh
Just noticed the power stering is not working so good at idle turning to the right - left works ok . when driving it is not noticiable. fulid levels are ok in ps pump. So what do you think pump or steering box ?:dunno
john
john
john-
is the alignment ok?
if so, the spooling valve in the gear is starting to go.
Fozz
Camarillo, CA
I had the same problem a few years ago, it was the steering gear box. I went ahead and put a new pump in too, since it wasn't too much $$ at the time.
94johnh
Calvin alignment ok . I was thinking of doing a flush of the system just for fun.
Fozz you are right if I go iin there I might as well change both..
Thanks
john
