Pop tester
cpdenton
Truck needs paint.
Conway AR
Hey guys! Don't think I needed this, but I saw it on craigslist for 50 bucks, so I couldn't pass it up.
It's pretty dirty, so I will need to clean it up. It does pump pressure, although I don't have an injector to check it with.
One question...what type of fluid are you guys using?
Just diesel?
Thanks
Chris
cpdenton
Truck needs paint.
Conway AR
Thanks guys. That's what I thought, just wanted to be sure.
Plus, you get that awesome diesel fuel spray on you that makes you smell like a real man!
BTW...wicked cool deal on that! ;Sweet
Get this to wash off the mist when done!
;Poke :rotflmao
typ4
Newberg,OR
I have one that is full of stanadyne fluid to clean the varnish then I use the diesel filled one to set pressure.
Russ your a cheater using 2 testers with different fluids in them. I just use one with diesel in it but. I make sure the filter is new and in place. You make me envious all the time with your nat tools.
typ4
Newberg,OR
Lol, and there is another one never been used under the bench.
lewisstevey7
