93IDIT
As the title states, I've finally resolved the issues that I have been having with my brakes. The driver's side rear was dragging horribly. The heat caused the axle seal to fail so I put in a new one. I rebuilt the rear brakes with new shoes, springs, and hardware at the same time. I tried removing and lubing the cable but it kept dragging intermittently.
Anyways, the resolution was found from TSB 96-24-12 . Apparently, the factory routing takes too sharp a bend and causes the cable to bind. Instead of using a "windlace" as the TSB says I just cut a four inch long piece of fuel hose to prevent chaffing.
Hopefully this info will help anyone else who is facing this issue. BTW, BBB industries has free access to TSBs at http://www.bbbind.com/tech_database.html
Now I can start worrying about how to fix the shower heads in the front and rear tanks
