parallel turbos
1mouse3
il
Shouldnt the frame straighten itself out once its bolted into the truck? Or is the truck also tweaked?
The state of the core support, is in send it state and at least its mounts points are still there. Every one I have found in the yard so far on a diesel truck, have been rusted to point of being unuseable. Im going to run with this till l cant no more, or when I can fit a new one in budget.
1mouse3
il
I got my self a way to open the hood. I aint going to try bending this think of metal without a brake, so bought a premade object.
I also put some acid on the core support, so wont wither away on me...
And same for all the brackets need to assemble it, paint will be another day. The core support stayed a little bit, so left it under tension and maybe it will get better memory this time.
1mouse3
il
I got a batch of painted parts...
And some paint thrown on the core, so its assembled for the final time.
Then had to find where I stashed the hardware for the filter head...
And got that assembled as well, need find where I got the extra newer hose since this roughly 10 year old dont look the best anymore.
1mouse3
il
I got the battery tray sorted and ready for install...
So scrubed them with a rough pad, cleaned them, then reapled the acid and is left to marinade.
1mouse3
il
I put a newer jumper hose on filter contraption, since had it apart and unsure on the 10 year plus hose that was on there...
Under inspection of the old, I see it still soft and the outer weave is nothing to worry about...
So this old gates lock on hose will be sent again, along with the rest I have for the run. The other hose Im using is eaton easy couple, since was what could find local.
So have the filters reinstalled...
And the batterys...
Torquing these bolts where a bit too soon, since the paint was still soft and caused chiping...
The tray is stood off from the frame with all these spacers...
The threaded rods I have to hold down the batters, are now too short with the lower support bar. So will need to get longer one, to finish mounting the batterys.
1mouse3
il
There is progress...
With placement of the turbos give enough room for exhaust pipes...
And there is room for a charge pipe on the driver side.
1mouse3
il
For several days and many days ago, I started with trying to fight with the transmision. I found out too late the tcase was in nutral, so rocking the engine around did not get the clutch alined. So doing all this was in vain, since got a odd pop...
So had to dismantle the trap...
This is done with a well supprted engine on its mounts...
This all is to fix the noise that arose...
Just to, have my finger back init to reset the trap...
Having this mount off will let me close this...
Dont worry its supported by two straps and yes the cupholder are not home yet...
Now with the trap closed, there is satisfaction of completion.
1mouse3
il
I have gotten the engine dressed up..
Then the core gets fitted up with missing pics, like of the dual SHO fans tied up with some bailing wire...
The passenger side turbo, want to fight with space for the inercooler pipe...
So flipped it, so it can be ran to someone to make coustom ones...
And something like this is what Im goind to make work...
this one has all the space in the world, some what for now till the ps tan is in place...
These two pieces off the turbo where perfect fit, but time messed them up some how. That and would need to find way to space this out some...
This side exhaust is in place somewhat...
This side is just sitting around right now.
I tell you what.....this is the part of the project that seperates the men from the boys. There's "starters" and there's "finishers". I have to force myself to finish something, but since I know I'm a "starter" and tolerably decent "finisher" I know where to hit the gas.
So come on Oil burners and let's give the @1mouse3 a strong push the the finish line or "end zone" or....... ignition switch.....or probably the diesel pump when he lights those turbos off!!! Whooooaaaaaaaaa @1mouse3 !!!!!!!
