So Im redoing all my steering hardware from the pitman arm up to the firewall (gearbox, shaft, pump/reservoir and hoses) however I want to get all the parts together before I tear it all apart, a quick search for the pressure hoses returns 7 possibles for a 7.3IDI 91 F250. Anyone have a part number or info to help figure out which hose I need? Also whats the best way to cap off the ports for hydroboost untill I get the rest of the components? (figure since Im changing the pump might as well upgrade to the hydroboost parts while Im at it) Im assuming the return line is just a basic soft line that can be cut to fit?
