Over the axle pipe
PwrSmoke
Northwest Ohio
The biggest I've seen is the one DynoMax makes for their 4-inch kit for our trucks. It's part number 54387 and it comes with the Ultra Flow welded 4-inch kit #19429.
jhnlennon
WI
IIRC 5" axle pipe wont fit without denting it in because of clearance with the fuel tank crossmember. Might want to check up on it. A 4" pipe is a tight enough fit, that I know.
zebrabeefj40
Pepperell MA
How different are the bricknose trucks vs. the OBS trucks? I ask because I used a 5" kit from Summit for a 2000 Dodge 24v truck under my '92. Yes, I had to cut a few hangers off the pipes and reweld them to fit the stock Ford locations but the pipes fit surprisingly well. Food for thought.
Nick
Feed Bunk
Cow hand
NW Missouri
Diamond eye makes a 5" for the obs fords. I got there cat back setup to put on my fummins and it seems to work okay, its a tad bit overkill though. haha
alienturtle
Human
Ripon, CA
Nick
i understand i will have to move hangers that is not an issue at all. Just wanted to make sure 5" over the axle pipe will clear everything. So you used a kit for a 2000 24V and the over the axle pipe cleared everything? Any pics? Thanks!~
They only show 4" for the fords?
junk
Paullina, IA
I put a walker 4" over the axle piece for like a 2000 superduty in my 89. Fit awesome. On my long box I thought I had all sorts of room. If it was me I'd order up a 5" over the axle pipe for a 2000 superduty and have fun.
On mine I also bought 10' of 4" pipe. Cut 1 foot off and installed. So 9' of straight pipe to the over the axle piece and done.
zebrabeefj40
Pepperell MA
I used Summit exhaust PN SUM-680009 http://www.summitracing.com/parts/SUM-680009/
Bought it the same time I bought the 24v Cummins planning to install the exhaust when I installed the motor. Then the IDI exhaust fell off so rather than continue with the restrictive system I had I installed the Summit parts. I figured I bought a box full of pipe that I would have to cut up to make fit the Ford. Not the case at all. I had to cut the hangers off and cut one piece to length. Since I know the down pipe wouldn't fit I cut that to fit the IDI y-pipe. That was just cut to length and rotated over to hit the y-pipe instead of a turbo. I'll try and post a few pics...
Nick
alienturtle
Human
Ripon, CA
Who needs more than 4 inch pipe on a IDI???
when you have to let this guy breath :sly
Nick
Thanks for the pics!. Looks like the 2000 superduty or the dodge over the axle pipe will work out well. Ill just order one of them. Im looking for just the other the axle piece. Thanks for the help.
m2rtin
