TBigLug
I Miss U Baby Girl
First, some backstory. My temp gauge always runs between the O and R of NORMAL. Sometimes not even getting over the N. I drove out to Ann Arbor today to pick up some groceries at Meijers. Everything worked fine. Got in and started heading to Dexter to pick up Heather looked down and my temp is running between the M and A. Weird, maybe the T-stat hasn't opened up yet. So I keep driving. Get to a stop sign. Sit for 20 seconds or so to let some of the traffic clear. Get back on the gas to go and the needle shoots up to past L and heading for THE LINE! I turn the heat on hot and ful blast fan and as I keep moving it drops back down to between M and A. Goes on like this all the way to Dexter (10 miles) and all the way home (25 miles). Just as I pulled into the driveway, strange, needle goes back down to between N and O. I thought the motor was making more noise while the gauge read hot but it could have been all in my head. Other than that, didn't notice any difference. If it wasn't for the gauge reading hot I'da never known.
My first instinct is water pump. Maybe while idling it's not moving enough coolant to keep the temp in check but when up to speed it's using the extra air flow and rpm's to keep things almost in check. I checked and all the belts were still there. Everything's too wet (1.5 inches of rain today) to see if there was coolant leaking out of it. Do Ford water pumps have a weep hole like Chevy's do?
Any other ideas?
Any other ideas?
