cewofford
7.3 IDI Turbo
Thank you for all your help in dealing with my glow plugs and thermostat. Next few problems I need to work through are to fix my fuel selector valve which i have a pretty good understanding of. Since I purchased my truck 3 months ago I have been steadily battling power window problems. Driver window has always worked fine. Passenger window works for a little while then stops. I removed the window motor and unplug it then put it back in and it works. Back passenger rolls down but wont roll up without help. Sounds like its slipping but i cant see how unless it needs a new regulator? That sound possible? Back driver window never worked. I replaced the motor with a brand new one and it worked two days and now it doesn't. My driver window switch cover is broken. I think part of the problem may be coming from there. Does anyone have that part for a crew cab four power windows with lock, power locks, and power mirrors. LMC doesn't carry it and ford discontinued it. No luck so far at the Wrecking yard.
