oldmisterbill
Grumpy Old Man
Seeing as that is in my stomping area (all of New England)its a small area. If you do get snow it will be cleared within 24 hours ( but you should be able to travel right through the storm).On the other hand you probably will encounter some slippery roads at some time or other.If you are there and gone before Jan1st you most probably won't encounter temps below 5*. The middle part of Jan is the coldest. As far as plugging in the block heater, 2 hrs of plugging in your heater will do the trick easily. If you get the priviledge to drive in a storm -depending in the temp (colder = dry drifting snow while warmer makes heavy wet snow) Wet slush is trecherous as it throws the front end back and forth as you hit the ruts -drive in others tracks or if possible a lane of nice clean un broken snow is best for saftey and traction. I prefer unbroken snow to rutty slushy roads. When traveIing on slushy interstates I don't change lanes (dangerous). If I have to change lanes do it gradually. two things to remember driving on snow & ice-1.drive as if you have no brakes,2. dont make any quick turns. On slippery roads us 4wd but remember you can excellerate faster then you can slow down. So use yout transmission for braking when possible.
I like howes best for preventing frozen fuel.
Don,t drive on wet bare roads in FWdrive - you will break something! (like shafts-diff gears-axles etc.) You can make a peice to cover the front of your radiator ot of any peice of cardbord you find behind a supermarket by th dumpster.I would put any thing in front of the radiator unless you can't get the truck warm enough. You shouldn't have nay starting issues if your truck is in good shape battery -glow plug and starter wise, hover you will find cold weather starter is a lttle different then warm weather.Develope your own way to start it.Make sure you use all your glow plug time to preheat.
You should be there to experience one of the most beautiful Christmasses God can give you to share the celebration of his sons birth.
Good luck Mr bill
Good luck Mr bill
