On to some smaller stuff..
BrianX128
Pittsburgh
So, now that I got the 85 6.9 running good I'm trying to think of everything I need to fix that isn't critical but are still things I want to accomplish.
Today I screwed around for a long time getting a new reverse switch in the T19 and have reverse lights in the truck finally. I wired a toggle switch so I can turn on the regular reverse lights and the two custom led lights in the custom rear bumper on (I love anti-tailgating lights) and it was already on the truck so I'm using them lol. Had to replace the blower motor resistor as high or nothing wasn't very fun.
But there's some other stuff I cannot figure out. The dome light just doesn't work. I've replaced the bulb and wiggled it around, it won't turn on with the doors or the headlight switch. I want to send power to the wire that goes up there but according to google that wire is three different colors on an 85 so no idea what I'm honestly looking for there.
The head unit for the radio needs to go. I'd like to leave it original but the cassette player doesn't work so I can't play music from my phone. The radio seems like it's an awkward size. If anyone has ever swapped one out, did you have to get one of those weird plastic pieces with the slim empty piece under it so it all fits right? The speakers in the door are 6.5" too right?
The shifter for the T19 is a little wobbly side to side, are there bushings like in a zf5 or m5od that you can replace to tighten it up?
And lastly.. although not exactly related to a bullnose, this truck was not a factory ac truck. But someone didn't like that along the way at one point so they did something about it but they didn't do it right.. The truck has an ac bracket and a compressor that spins on it and also has a condenser in front of the radiator but that's all it has left. On the inside of the truck there are old controls under the dash. The previous owners got rid of "it" but I guess it was some smaller horizontal thing that sat under the dash mostly towards the passenger side that was hooked up to everything through the firewall in a custom hole that's not got a grommet closed off. I think it looked something like these that I just found online.
Except from 30 or so years ago. I'm assuming it would be a giant pain to ever hook anything back up to it, and at this point I should probably just take the compressor off to have more room in the engine bay and probably just leave the condenser as a shield for my radiator and use the windows. I'm guessing these things don't work well, are really expensive and hard to find and just not worth it.
At least I'm dealing with more fun items than an engine filling up with fuel in its oil lol..
As for the antitailgating light, I was driving an old farm truck back in the early 90s. It had one of those "through the pillar" spotlights on it. After a few miles of being tailgated with the brights on, I turned the spotlight around backward and turned it on. The driver got the hint and backed way off in a hurry! If you want A/C you could go the street rodder route. There's custom, aftermarket kits for installing A/C in old cars that never had it from the factory. The company Vintage Air comes to mind.
david85
Campbell River, B.C.
Sounds like a dealer installed AC system. It shouldn't be too hard to remove if you wanted to clean things up. I think the non-AC trucks had a second belt on the power steering instead of the AC compressor. That way you still have the three belt redundancy on your water pump.
If you ever wanted to have running AC, I would swap over from a factory AC equipped truck. Other than the ducting and heater controls, all the parts are still available new. I completely rebuilt my system late last summer. Compressor, hoses, evap core, condenser are all available online.
Ducting and controls could be sourced from wreckers, but it would take a little while to scrounge everything together.
Door pin switches come to mind for dome light issues iirc
Sounds like you may need to upgrade to a nswer din size knobless radio...sadly....go to wrecker and get anothsr trim panel so if for some reason u want to u can go back to knobs.
There are wiring adapters the plug directly into factory harness....u then wire to new radio harness....no cutting involved.
Door speaks 5.5 iirc 6.5 fit with some mods....use a mdf backer boardinside the door and some XTC speaker baskets for weather proofimg and better sound.
Vintage air or xelete...yer choice.
JM7.3CW Eh!
JAKRANCH
Benson, Utah
I've got the same a.c. system in my truck. It is a freezer its better than any factory a.c. I've had. Whatever works the best fit you but I wouldn't trade mine
BrianX128
Pittsburgh
So I got the dome light to work but not from the light switch just from the doors. I just added a toggle switch if I need to turn those on from inside.
Replaced the head unit and had to totally rewire that previous owner disaster. New speakers as well.
Now the next thing is the god awful dim green lights for the dash cluster. I wouldn't mind the green if it was brighter but it's awful..
crash-harris
Breaker! Breaker!
Chillicothe, OH
I have an evap canister and at least one uncut A/C line if you want the A/C back. Word of warning, check the condenser and make sure none of the little tubes are cracked or broken off.
austin92
Brazil. IN
I use a radio transmitter for music off my phone. It plugs into the headphone jack and emits a radio frequency of your choice. Tune the radio to it and you have your music. Runs on 2 AAA batteries, I got rechargeable because it goes through them pretty fast.
