Old truck - New owner. It needs some love.
Ryan Cowper
Redding CA
I'll fill it up today and let you all know. If the PO's took half as good of care of the engine as they did the interior, I'll be one lucky guy. Darn near looks factory fresh in the cab.
Ryan Cowper
Redding CA
Well good news. That tank I blew through and figured I got around 8mpg was only half empty. It only took 9.8 gallons when I filled it up. That is a relif. I got the Hotshot anyhow and its in both tanks.
austin92
Brazil. IN
I run stanadyne lubricity formula year round and add Howe’s in the winter. Does its job
Ryan Cowper
Redding CA
I'm starting to question if my truck started it's life with an automatic transmission... I've never seen a manual transmission with cruise control. Would someone be able to look at this door sticker and decipher if "trans C" is manual or auto?
Thewespaul
Bulverde, Texas
C is a three speed manual for the F series trucks, likely a typo on the tag. If you take a picture of the injection pump tag I can tell you if it was calibrated for an auto or manual. Plenty of manual trucks had cruise control in this vintage
Ryan Cowper
Redding CA
@Thewespaul I don't see a tag on the pump. There's this engraving.
Edit: I see it now. Might be difficult to get thst pic...
Thewespaul
Bulverde, Texas
That’s your rebuild date, here’s the tag you want
Which probably doesn't mean much since it's been rebuilt. I'd guess that the chances of it even being the original pump to your truck aren't very good.
Ryan Cowper
Redding CA
@Thewespaul So, my suspicion is correct. I have a 5 speed manual with this tag. We're there specific specs that needed to be done to the injector and\or anywhere else after this swap happened? Since this truck is new to me, is there a good way to check the competancy this swap.
Ryan Cowper
Redding CA
Point taken. Any other ways to tell if a manual\auto trans swap has been done?
