Old Spice to the rescue
I tried the Old Spice solid this morning, it was 50* and it didn't work, gotta get a spray can. Will Right Guard work?
CDX825
filtration nut
Litchfield,Ohio
Right Guard doesnt have near as much good stuff in it. You can give it a try though.
I could never get it to work with my potato gun.
My test for fuel was if I could light the spray and it would stay lit without the lighter it was good stuff. If it wouldn't stay lit it wouldn't fire the gun.
Wyreth
Certifiable Noob
Las Vegas, Nv
I might even worry about Aquanet having too much cowbell actually. =P
That stuff is damn near nitrometh.
Wyreth
Certifiable Noob
Las Vegas, Nv
bayou
marysville ca
the stuff that can be used to start an engine is crazy
mosqueto spray
deoterants
put gas on a rag and wrap it around your a/f
put a propain torch in your intake. (not flaming of course)
foaming engine cleaner (hey it works)
wd40
yup i get desperate cookoo
Kevin 007
Full-floater
Nelson BC Canada
I have often used a oxy acetylene torch to heat the intake manifold and jumped out the starter solenoid to crank the engine till it starts while still holding the torch down the manifold..far easier on the engine than either or any starting fluid
