Moosebob
Ok so I dropped the pan and took off the pump and found..... nothing! Pickup tube was clear, pump turns fine and pumped well when I stuck it down in the oil pan and spun it by hand. Oil filter looked fine inside what I could see. Flashlight shows clear oil galleys and compressed air made some oil bubble out way up at the lifters and I could feel it at the turbo fitting.
However when I had cranked it before, I got no oil dribble out the front port. Thanks to Oldbull I see also that there is a plug in that one hole. Mine does not have that plug. Not sure if that matters in my case as that should just let oil directly into the galleys, but oil would be able to bypass the filter doing that.
Only thing I can think of is simply the oil pump. I know I'm not the first one inside this engine and I don't see anything that looks like an International part number stamped on it. I did open the oil pump up and clean the sludge out of it before and now I have no pressure. Maybe it's a junky pump???
